Need inner pass side kick panel pic
Old Feb 27, 2013 | 04:52 AM
Nefarious79's Avatar
7th Gear
Default Need inner pass side kick panel pic
Can someone remove their passenger side kick panel and take a pic? Need to see how the relays are supposed to be laid out. Mine is just all stuffed in there :/
Old Feb 27, 2013 | 07:31 AM
There is a download that is free.
It is called the RAVE (Rover Automated Viewing Environment).
It contains the electrical drawings, connector pin outs, color codes.
It also includes detailed photographs of the device locations.
Once downloaded, it will provide endless hours of enchantment and become your favorite Brit Lit. Even at 3:37 AM.
A sample is attached. You will note that unlike photos posted by members, it includes details of which connector and relay and such so you will know what you are looking at. The RAVE for the D2 is in color.
If you can't download the whole RAVE, sections are also available in a link below.
File Type: pdf
Old Mar 1, 2013 | 02:42 AM
7th Gear
Its not so much the connectors or wiring, as much as it just the layout. Need to see how everyones disco has the wires routed and relays mounted, so I can put mine back together how it came from the factory.
Ill take a pic tomorrow and post it to better illustrate my point
Old Mar 1, 2013 | 07:24 AM
here tiz
Attached Thumbnails Need inner pass side kick panel pic-d1-kickpanel-layout.jpg
Old Mar 1, 2013 | 08:03 AM
Note: I just got to your other post with the "I asked for a pic from behind someones pass. side kick panel not a finger towards the RAVE manual. "
Enjoy your continued search for the solution. If you are not an experienced electrical person, this may not be the type of repair to conduct DIY, in particular if you don't like assistance that is offered.
Robert Booth
Mar 15, 2015 10:06 PM
lr3bushings
Jun 21, 2013 12:26 AM
pottzie
Jul 17, 2012 11:34 AM
killerpav
May 7, 2012 12:23 AM
Lincoln Tarantino
Oct 11, 2011 12:05 PM
