It NEVER ends! Fuel delivery issues continued... :(
1996 Disco 1 SE7 4.0
I recently posted and got help with replacing injectors, and it was a bear to change them, and pricey but I got it done thanks for the help guys... However, they were not my problem ... Before putting all my lines and hoses back on in full I clipped the injectors in to the rail and pressurized the system to check for leaks ( i know not real professional lol) all was good, however about 10 seconds of having the key forward, the line on the fuel pressure regulator the one that goes back to the intake plenum started spraying gas like projectile vomit... Guessing I found the cause for all the gas in the block... However now I need to know, and I am sure this is a really stupid question and I am sorry for that, is the gas coming out of the regulator due to a faulty regulator, or due to a faulty vacuum connection not engaging the regulator? I'm sure before you answer you will laugh at me, and that is fine by me lol, I'm not a mechanic just can't afford to pay one either lol, and don't want to order anymore un-needed parts as the injector set was not cheap at all
... However, as I assume with no vacuum being as the motor is off, it IS in fact a bad regulator, which is crap because the previous owner said they replaced it as one of the last attempts to fix it before I bought it, looks used at best
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
Yes, the fuel comes in to the regulator, the nipple that connects the hose from the regulator and attaches 4 inches of hose away at the nipple on the plenum, if connected it would be pushing gas directly into the plenum, and into the block from there, that was my original problem lol -_-
It was in fact the first thing I assumed was wrong, however ,like I said the previous owner told me they had already replaced it in an attempt to fix the gas in the block issue, I should have just ignored what they told me and changed it anyway lol... Thanks a ton for the specific answer without making me feel entirely retarded lol
Based on the markings this part is correct. Same as the one I bought over the summer.
So, if this is what the seller is claiming it to be (NEW), buy it. If you don't, I'm going to grab a spare. ETC8494 Fuel Pressure Regulator | eBay
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
