NGK / NTK 25044 OXYGEN SENSOR doesn’t fit my 96
Hello Good People,
Finally bit the bullet and needed to switch out my O2 sensors.
Got in there and it’s a no go with the new NGK / NKT 25044 sensors.
In the image below you can see the new 25044 sensor on the left has some kind of tab inside that is in the way. The sensor on the right is the one removed.
Any way to get this to work?
What sensor should I be looking for at this point?
Thanks
Thanks
It looks like NGK 25017 is what I am looking for.
Question: Would it matter if I spliced the head of the old sensor onto the new one ( NGK 25044)? If so I will put these in the downstream position. I bought them months ago and can no longer return them.
The upstream will have new NGK 25017 sensors since it’s a pain in the butt to swap out so best to do it right the first time without any splicing
Thanks
Thanks
The type of O2 Sensor depends if you have a AEL or Non-AEL (Advanced Evaporative Loss) System.
Some useful INFO>>>
> https://www.roverparts.com/Techtips/know_your_emissions_system.cfm
> https://www.roverparts.com/resources...ssions-system/
The NTK 25044 is for a truck WITH AEL...
looks like you need the NTK 25017 (for a non-AEL truck.)
Some useful INFO>>>
I looked on the NTK site and while they give a detailed listing of all products offered ( NGK & NTK ) there was nothing re: specs.
Have a look in " PART FINDER " > https://ngksparkplugs.com/en/
Here are the listing and descriptions for both the 25017 and 25044 (the site has very detailed pics)>
Toran (10-04-2020)
