No matter how long I stare at it
I can't figure out how to change in the new rear end caps on my '98 D I. Has anyone out there done this? From the new ones, I can tell they are secured at three points by small phillips head screws. The only problem is that when they're on the truck, such as the ones I'm replacing, you can't get to the head of two of the screws! Thoughts? I would just bust them off, but then that leaves the problem of putting on the new ones, which would be the same issue.
When I pulled mine off to paint them I took the entire bumper off so I could paint it also. If memory serves me right its only two bolts to remove the entire rear bumper then disassemble to your hearts content. Have fun.
The bumper caps are each attached to the bumper by a metal bracket. Remove the metal bracket from the bumper (it's attached by a few bolts) and then once that assembly is off go ahead and unscrew the end cap itself with a phillips screwdriver. Assembly is reverse of disassembly.
Spike555
Jun 20, 2012 09:24 PM
audiS4S6
Apr 18, 2010 11:02 PM
