o2 trouble codes..confused
I'm getting these trouble codes..obviously I have a o2 sensor issue..but which sensor? ![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
P1193 Oxygen Sensor Heater Circuit Open Downstream
P1187 Oxygen Sensor Heater Circuit Short Upstream
P0158 Oxygen Sensor High Voltage *Codes* B D
ahh I see now...bank B downstream...is bank B driver or passenger side?
http://www.obd-codes.com/trouble_codes/landrover/
Going by this site, B-bank is the pass. side. A-bank has #1 cyl. on it, which is the first one on the driver's side.
Folder name - PDF
sub folder name - lj
file name - etlj960x.pdf
Section - A1
page - 3
start there...
right.... 1 - 86 is the workshop manual. Maybe you only downloaded the WM and not the full rave? the download I'm talkin about is a large file at 590Mb http://www.landroverresource.com/rave.zip
When you download the entire rave and unzip it you should see a single folder entitled rave. when you click on that you get some subfolders (Indexes, pdf, rave tutorial) and other files (Autorun... ) and then a few PDF FILES. if you click on the pdf FOLDER you will see folders named "general, ld, lh, lj.... library....)
when you go to lj you will be on the right course...
this is like a friggin treasure hunt...
