Oil pan gasket or rear main seal?
Getting around to chasing a few oil leaks and there’s one I can’t 100% identify. After degreasing and pressure washing the entire undercarriage, I’m getting a drip right off the front of the bell housing. It’s not much, maybe a 1.5” spot on the driveway after sitting overnight. Every bolt on the oil pan was loose, took 1/4 turn (a few a bit more) to snug each back up. I’ve got 163,000 miles and that’s the only leak I’m currently chasing. Had a few leaking hoses and a leaking valley pan, all of which have been fixed. Should I go ahead and replace the oil pan gasket and see what happens? Or would a can of Blue Devil be a better option to start with? |
I had a leak just like that and it was the oil pan gasket. The oil pan and gasket is pretty easy to change so I would start there. My rear main seal wasn't leaking even after 190K hard miles. I would always start with the easiest solution first. You can also pull off that inspection plate that is held on by the 6 or so 8mm bolts and 2 11mm bolts that it's dripping from and you should be able to see trails if its coming from the main. You will want to take that plate off any way to refit and remove the pan.
Thanks, I’ll plan on swapping it out with the next oil
change. Anything else I should do while the pan is off? |
Go ahead and pull the oil pickup tube off and clean it will well. The screen will clog up and will Restrict oil flow. |
Originally Posted by aemnky606
(Post 657601)
and a new o-ring for the oil pickup
Will do. After some research, it looks like a lot of guys are using “the right stuff” in place of the cork gasket. Is that the preferred method for the oil pan? |
Yep'r
Originally Posted by s10lowrider1994
(Post 658047)
Will do. After some research, it looks like a lot of guys are using “the right stuff” in place of the cork gasket. Is that the preferred method for the oil pan? When the excess breaks away from the oil pan, the RTV makes its way into the oil pickup and blocks the screen = :cry: |
Originally Posted by WaltNYC
(Post 657900)
