Oil pan gasket or rear main seal?
Old Aug 10, 2018 | 03:14 PM
s10lowrider1994's Avatar
Default Oil pan gasket or rear main seal?
Getting around to chasing a few oil leaks and there’s one I can’t 100% identify. After degreasing and pressure washing the entire undercarriage, I’m getting a drip right off the front of the bell housing. It’s not much, maybe a 1.5” spot on the driveway after sitting overnight. Every bolt on the oil pan was loose, took 1/4 turn (a few a bit more) to snug each back up. I’ve got 163,000 miles and that’s the only leak I’m currently chasing. Had a few leaking hoses and a leaking valley pan, all of which have been fixed. Should I go ahead and replace the oil pan gasket and see what happens? Or would a can of Blue Devil be a better option to start with?
Old Aug 10, 2018 | 04:41 PM
Crunkgringo's Avatar
I had a leak just like that and it was the oil pan gasket. The oil pan and gasket is pretty easy to change so I would start there. My rear main seal wasn't leaking even after 190K hard miles. I would always start with the easiest solution first. You can also pull off that inspection plate that is held on by the 6 or so 8mm bolts and 2 11mm bolts that it's dripping from and you should be able to see trails if its coming from the main. You will want to take that plate off any way to refit and remove the pan.
Old Aug 10, 2018 | 04:55 PM
Thanks, I’ll plan on swapping it out with the next oil
change. Anything else I should do while the pan is off?
Old Aug 10, 2018 | 06:29 PM
aemnky606's Avatar
Go ahead and pull the oil pickup tube off and clean it will well. The screen will clog up and will Restrict oil flow.
Old Aug 10, 2018 | 11:05 PM
I was going to say the same thing.
Old Aug 12, 2018 | 04:11 PM
WaltNYC's Avatar
and a new o-ring for the oil pickup
Old Aug 13, 2018 | 01:57 PM
Will do. After some research, it looks like a lot of guys are using “the right stuff” in place of the cork gasket. Is that the preferred method for the oil pan?
Old Aug 13, 2018 | 02:09 PM
ihscouts's Avatar
Yep'r
Old Aug 13, 2018 | 02:26 PM
OverRover's Avatar
Just DON'T overdo it with the RTV!! This is usually the biggest mistake people make.
When the excess breaks away from the oil pan, the RTV makes its way into the oil pickup and blocks the screen =
Old Aug 13, 2018 | 04:48 PM
I see this come up all the time but if you have a GEMS were the pick up tube is halfway down the block you won't have an o-ring to replace. The pick up tube has to come from the timing cover in order to have an o-ring.
