oil smells like gas
Old Jun 8, 2011 | 07:34 PM
deer killin disco's Avatar
there dosnt appear to be any oil in the coolant. i looked in the over flow tank is there a better way to check
Old Jun 9, 2011 | 10:50 AM
yloDiscoII's Avatar
I think you'd be shopping for a new engine if there was oil in the coolant reservoir
Other way around, check the oil for coolant....your oil will be brown and milky.
Old Jun 9, 2011 | 11:05 AM
I love it, with all the replies, no body even hit close to the issue.
Other then you could probably use a tune up, Rover engines burn rich and as such the oil smells like gas, it is not rings, head gaskets or the need for a new engine.
So not knowing what you are using for gas and how long it has been since you have done a good tune up along with 8 mm wires, maybe an induction cleaning and a can of 44k and you will be in alot better shape.
Old Jun 9, 2011 | 11:31 AM
Chris-bob's Avatar
Originally Posted by LRD2&ME
No one who owns a Disco should have problems with a little fire. NOTE: Pull the dipstick from the tube and allow the oil/fuel solution to drain into a jar. Be very careful when you toss the match in. A flame could possibly ignite the oil/fuel solution. Have a bucket of water available. If you have a fire extinguisher have that available as well. Toss the match in the jar at least 50 feet away from any flamable object or building. Do not stand into the wind when tossing the match into the jar. Wear safety glasses and a full body fire retardent suit. God be with you.
What about the weinie roast...
Old Jun 9, 2011 | 11:32 AM
Chris-bob's Avatar
When was the last time you changed the oil?
Old Jun 9, 2011 | 11:37 AM
He mentioned about 1000 miles ago.
Old Jun 9, 2011 | 11:56 AM
yloDiscoII's Avatar
Originally Posted by Disco Mike
....no body even hit close to the issue.....
Way to go dummies...
Old Jun 9, 2011 | 12:34 PM
my oil is a brown but im not losing coolant. this weekend im going to do a induction cleaning and change plug and wires do a compression test and change oil
Old Jun 9, 2011 | 01:01 PM
Chris-bob's Avatar
Yeah, for some reason I missed that. I'd start with a tune up if needed and another oil change.
Old Jun 9, 2011 | 01:27 PM
yloDiscoII's Avatar
[QUOTE=deer killin disco;251046]my oil is a brown.....[QUOTE]
Is it "milky" at all??
