Ops I got no plastic Oil Separator in the breather tube
Hello Good People,
I am missing the little plastic tree like oil separator in my breather tube.
Before picking up one on eBay is there an alternative to one that can be picked up at a hardware store etc?
Also what are the negative effects of not having this little device missing in action. I want to know if I am already feeling the negative effects.
This little squiggly thingy basically condenses oil vapor and leaves it in the valve cover instead of allowing it to pass to the plenum and soil what should be a relatively clean air intake. Your throttle body can get gummed up and eventually you loose air efficiency.
fyi, it is also known as an oil trap or oil separator.
I would probably opt for the separator (original) over the PCB to retain the designed function. The weighted, metered orifice design of a PCV is a more abrupt way of exhausting vapors, where the orig. trap design is a more even flow. If you could be sure it would stay in the hose, a piece of Brillo pad would be a closer function to orig. design.
I played with options on an old Chevy straight 6 in younger days and finally went back to orig design. My .03 cents... Russ
I'll bet the 2-3 days to get an original wouldn't gum things up enough to stress over. Russ
PCV valves vary in the diameter of the hole through the inside and the weight of the "valve" inside to match the breathing quirks of different engines. Just a little more to think about.... Russ
Yeah and usually the flow 0% as the OEM baffle can easily clog up.
I would go with a nipple style PCV which had a similar size opening to the OEM baffle/hose diameter.
Then install it with the proper flow direction and call it a day.
For the record I checked my 97 XD and that OEM baffle isn't even there. On GEMS engines you have two places that clog. The OEM baffle, and the much smaller diameter metal nipple at the intake. PCV size is really not a concern due to the small diameter at the intake. Don't over think it.
I'll see if I can find a suitable PCV and post it up when I can.
I appreciate the response.
I am over thinking it though I didn’t mean to. Such a visual creature I am.
The valve looks like something from off an air compressor hose.
