Overheated In The Drive-Thru
#21
so what is the max coolant temp where I should be concerned about damage? Have heard plenty of different numbers, I have seen my truck go up to 220 and the gauge was pegged.But then I have seen the gauge in the center range from 190 to 217, once it hits above 219, it rapidly pegs out. I am guessing I have a bad gauge...
Using my OBDII scanner to monitor temps so maybe I am reading a bad sensor?
#22
#24
Just got my two motors, which were pictured as the circular/vertical plugs like OEM. Turns out they lied and they are rectangle ones. Guess I’m going to have to do what you described and I’m not happy about it...
#25
The toyota fans = totally different plug. If you want the correct plug expect to pay 250.00 each for the OEM LR efan assemblies.
Cut the old plugs off & splice them onto the new fans and call it a day. Use some 3M heat shrink butt connectors and they'll be good to go for many many many many years!
#27
Well, after a few weeks with new Camry radiator fan motors my truck has once again overheated after idling for about 15 minutes. By “overheated” I mean the temp gauge went all the way in to the red. With my new Ultra-Gauge installed, I could see the temp reached about 206 Fahrenheit. Is that even hot for these engines?
I’m going to chalk this one up to a poor exhaust system. I can tell everything (except the cats) from the manifold to the tailpipe is 23 years old and crusty.
#28
#29
#30
It was only about 70 Fahrenheit outside, no A/C. Truck usually stays at 170 while driving.
I’ve also noticed some dried coolant around my thermostat housing. I’m thinking my Motorad 180 degree T-stat is blocking too much coolant. What’s a better brand?
