P1179 Error on 1997 Land Rover Disco
My original thread can be found here (https://landroverforums.com/forum/di...-check-110332/)
Basically I had a P0300 and P1316, both were cleared with new plugs and wires. Codes were reset using OBDII and have stayed away. On the original diagnosis, I also had a this P1179 that I was hoping would go away by switching over to premium unleaded. This code was also cleared using the OBDII and stayed away for 3 or 4 days (not sure how many miles), however It just popped back up again this evening.
As my previous post explains, these is a brand new car to us and has been meticulously maintained. I have all the records dating back to the original purchase.
The MAF looks brand spanking new, although I havent looked/found when it was actually replaced. So excluding that, where would you start? O2 sensor?
Looks like the MAF sensor is only a few months old (replaced in 8/21). I called the shop that did the work and the guy said he would try with another brand of MAF sensor as he was skeptical of the one he put in. Something about not having access to parts due to their remote location and lack of smog restrictions on older cars in their state. He also said I may just want to clear the code, use the OBD to check for readiness and then limp it back to the smog place and try again.
It looks like this P1179 code is gone again. CEL turned off on its own. Im gonna run it in today and get the smog (hopefully). The fact that this code has turned on off on off again, does that point anyone here to a likely cause for the next time it comes on? Ill still hook it up and see if i can get 02 readings just for fun through
