Panhard Polybush done....finally.....
I've been slacking for about a month now. It is such an easy job, just couldn't bring myself around to do it. Well....its done.
I pressed out the original bushings using an 22mm adapter, which took about 10 minutes total. It took longer just to set up the press. The bores are really rough, so I cleaned them up. Lubed, then pressed in the new bushings and installed them. I opened up each bracket, since it was too tight to fit. Once opened slightly, it just need a little persuasion from my mallet. Fitted bolts and nuts, then torqued down....done.
Steering input feels a bit more direct, a little less slop. But, that was just taking my daughter 2 miles to get something to eat.
Plan on driving more today...hopefully get to the OHV park later today.
Also, I just got an adjustable panhard in the mail. I'm going to replace it tomorrow, when removing...word on the street is the whole truck shifts out of alignment...any tips?
You love your Polybushings, lol.
The axle will shift a little when you pull the old rod. Put the old and the new next to eachother and lengthen the new one a bit. Attach the axle side. The line up the frame side. If you have a helper, have them turn the wheel slightly. It will make aligning the frame end easier.
The inner ring is 22mm, which will push the ring of the stock bushing perfectly. I forgot was the outer was, but you can find a large enough socket for it.
If you have a 4x4 ball joint press tool, it probably should work also.
