Parking Lights Mod?
Parking Lights Mod?
Hello Good People,
I've searched the forum high and low and was wondering if anyone had done a parking lot mod. I am interested in manually turning my side markers and all amber lights on during that time of day before headlights are needed.
Curious if it has been done, and what is needed to make it happen. If I dont like it I will return it to stock. I miss this feature that was on my late 80's vehicles.
T.I.A.
T.I.A.
I returned outside and found my "parking lights/city lights" to be working. The parking lights are the small lights inside the headlight housing that come on when the headlight switch is in position #1.
I found a thread on DiscoWeb saying the D1 doesn’t have parking lights and that the Ambers only come on as turn signals. If this is the cause than my headlight switch is functioning properly.
https://discoweb.org/showthread.php?...adlight+switch
Still...it would be interesting to get those Ambers on like mentioned in the first post.
T.I.A.
T.I.A.
The D1 has no side or front amber "parking lights". Your switch is fine. You can mod them easy enough because I believe the Defender had the turn signal/parking light setup.
Dual Filament bulb holder: Bulb Holder 3 Contact - Land Rover bulbs from Atlantic British
And the corresponding plug/pigtail. Bulb Holder XBP100190 Harness Repair Kit (8959ABP Same Fit As Part # 8959ABP ) - Land Rover bulbs from Atlantic British
You can probably source them from a junkyard and just wire them up!
Toran (10-30-2017)
