Part number for bosch upstream O2 sensor
Old Dec 2, 2011 | 09:29 PM
Discolife's Avatar
Default Part number for bosch upstream O2 sensor
I thought I ordered the right one. The box is listed 15175 for my bank 2 sensor 1. The sensor has female connector not male like is on my car.
Old Dec 2, 2011 | 09:47 PM
adigerol77's Avatar
Well then you ordered the wrong one now didn't you . Hang tight I'll check the part #.
Old Dec 2, 2011 | 09:48 PM
Discolife's Avatar
It said it would work. I suppose I can use butt connectors and fill with silicone for water proofing
Old Dec 2, 2011 | 09:51 PM
adigerol77's Avatar
What year did you order it for? Where did you order?
Land Rover Oxygen Sensors: Oxygen Sensor For Discovery & Range Rover Vehicles
Old Dec 2, 2011 | 09:52 PM
Discolife's Avatar
Amazon
Old Dec 2, 2011 | 09:53 PM
adigerol77's Avatar
Is this the one you received? Land Rover Oxygen Sensor For Discovery I, Range Rover 4.0 & 4.6, Defender 90 Vehicles
Old Dec 2, 2011 | 09:59 PM
Discolife's Avatar
Negative its in a bosch box and says 15175 Four wire but has a female connector where I need a male connector
Old Dec 2, 2011 | 10:04 PM
Discolife's Avatar
can I just splice the connector on?
Old Dec 2, 2011 | 10:37 PM
adigerol77's Avatar
Above my pay grade. I'd return and get the correct but I know there are many more much Yoda wisdom that can answer.
Old Dec 2, 2011 | 10:41 PM
Discolife's Avatar
I found a ngk at napa with the correct number and connector for 77 dollars.
