passenger air bag removal
Got a tray and grab handle to delete the passenger airbag, how do I get it out?
Just flip down the glove box and unplug unbolt or to you pull the dash |
You don't have to pull the dash. Can't find a link for the disco, but same as a 95rrc.
Supp Restraint starts on page 562 - 563 http://www.landroverresource.com/doc...anual_1995.pdf |
You can use a 8mm 12 point socket, but it's actually a torx outer socket. You will need at least a 6" extension, more like 10".
Drop the glove box down, there are channels bored out in the foam, 2 at front and 2 at back. 4 total. Undo them, pull the bag up and unplug the connector(battery disconnected if you are cautious!). |
With the bag removed won't that set off the SRS idiot light?
I didn't dig the tray underneath. That's why I didn't grab it. Post some pics when you get it in.
Thanks guys, scouts not sure bout the light guess I will find out
Hell if I found a non airbag steering wheel I liked probly remove it too, sun visors say service every x years |
The 4 bolts you need to remove require an E10 socket and long extensions.
I took mine out and my SRS light is on..
I can just pull srs bulb or tape over it lol I will get to it sometime this week
all my e sockets are in va so guess I will try 12 points |
Tape over it, it's faster.......
The whole mission when we get these things is to make lights go out. The longer and more bored we get we seem to make more lights appear........ |
