-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Prepping for paint (https://landroverforums.com/forum/discovery-i-39/prepping-paint-62440/)
disco12 Oct 14, 2013 04:57 AM
Originally Posted by lambo (Post 425544)
K, got that on the alpine s, thanks. How about sides, anything special? Got the first piece done. Krylon satin khaki
that will be nice color on the Disco when you are done
abran Oct 14, 2013 02:05 PM
I recently took out my Alpine windows and re-installed after rust repair. Take out the extra center trim in the gasket, then use a plastic pry bar to start from the inside working the lip out. It is a good idea to have someone on the outside make sure the window doesn't pop out. I used the same gaskets when I re-installed. There is a weird lip on the top that the gasket has to get around when removing and re-installing( I started at the bottom and worked my way around to the top). I added clear RTV in the channel to seal it up perfect for the re-install. I actually put the gasket in the frame, then aded the window starting at the bottom and working the top. Once it is all in, replace the center moulding piece. When re-installing the center trim, be sure to first start it at the top position, both ending edges butted up. Then push in in the corners, then pick equal distant points to push it in "the field"(if you start at one side and work your way around it will stretch and you will have too much insert moulding)
I have not done the sides, but if it is like my 23 window volks bus, should be easy. I use Talc powder and string and put it on the channel of the gasket that meets with the lip of the frame. Place the window in position on the outside, and start pulling the string out(on the inside)too get the rubber lip to come over the metal lip of the frame. Also have someone pushing in from the outside. It could be harder if the gasket is dry and has cracks.
Good luck!!!! Love the color. I am about to Plasti-Dip my silver one black and use a final coat of the "glorifier" to get a satin finish.
abran Oct 14, 2013 02:06 PM
Sorry, Not glorifier, Glossifier!!!
lambo Oct 15, 2013 06:01 AM
Thanks for replies and tips, ill post more as i continue
slanginsanjuan Oct 16, 2013 07:37 AM
nice. that's helpful.
i need to do roof only so that will include sunroofs.
abran Oct 17, 2013 07:45 AM
I have not done my discovery with sunroofs yet, but need to. I will post about removing the sunroofs once I get to it.
CUpgt Oct 17, 2013 08:27 AM
Sunroofs are cake. Remove headliner, remove drainpan and motor ford bolts and remove drain pan. Push the rest through the top. I changed my sunroofs with my SD rack on the truck.
abran Oct 17, 2013 08:36 AM
Great, thanks, mi guy happen this weekend.
abran Oct 17, 2013 08:37 AM
Sorry, "might happen" not "mi guy"
lambo Oct 26, 2013 03:09 PM
1 Attachment(s)
With only about an hour a day, it is finally ready to tape and paint. Rear windows removed without breakage even! Going out of town for work, so it will be couple weeks. Any tips on rear door latch assembly removal or atleast loosening it up to fix gasket, looks kinda like a pita
