bantham1 |
08-05-2010 12:15 AM |
Procedure for putting valley pan gasket on
I have removed my valley gasket on my 98 disco. I have one on order from autozone. It appears to be a complete kit with black rtv silicone. What is the proper way of sealing the gasket? Dry on the top and go around all intake ports and endcaps with the rtv or just the endcaps per rave? I do not want this leaking again and may put some blue loctite on the manifold bolts. My torque wrench will probably not fit so this could be a problem and I may just torque it down with a wrench tight. It was very tight coming off and I hope I can get it back on without removing the valve cover as autozone did not have a gasket for them.
