radio help needed
Old 11-21-2010 | 02:04 PM
pwr198's Avatar
Default radio help needed
Just got a radio from Tull but doesnt seem to be taking code. I want to make sure i'm doing right. can some one tell me the proper steps maybe I'm doing wrong
Old 11-21-2010 | 03:07 PM
Dezert Rover's Avatar
Leave it for an hour w/ the key in position 1, then try again. You have three tries
Old 11-21-2010 | 04:27 PM
pwr198's Avatar
so I leave ignition on for an hour?
Old 11-21-2010 | 05:45 PM
Rover Chris's Avatar
punch in the code that's it. If you try to many times it will then require a reset, this can only be done by leaving the unit powered on for about an hour, don't press any buttons during that time and don't try to start the truck. I would suggest using a battery charger if you have to do that.
Old 11-21-2010 | 07:06 PM
pwr198's Avatar
after an hour do I turn truck or radio then retry or do I just retry
Old 11-23-2010 | 10:20 AM
okdiscoguy's Avatar
turn the truck on and leave it on for an hour with the radio turned on.. Then try to punch in the code.
dogstarsix75
04-24-2020 02:33 PM
mtpotr
01-01-2012 10:05 PM
southfloridadiscoII
06-29-2009 12:03 AM
sph1nxx
Audio/Visual Electronics
12-26-2007 12:54 PM
