rear diff pinion nut torque specs
Old 09-09-2010 | 11:50 AM
NiteTrain's Avatar
Default rear diff pinion nut torque specs
getting ready to replace my pinion seal...shop manual says torque nut to 130 nm which according to my conversion chart is 90 ft./lbs...that seems a little low to ones i've changed on other vehicles..can anybody confirm manual is correct?
Old 09-09-2010 | 11:58 AM
okdiscoguy's Avatar
It is a nyloc nut. The torque is correct.
Old 09-09-2010 | 12:22 PM
NiteTrain's Avatar
i think that conversion chart i used was off...should of been 95.88 ft/lbs
Old 09-09-2010 | 06:57 PM
Whats a torque wrench?
Old 09-09-2010 | 07:39 PM
antichrist's Avatar
http://www.onlineconversion.com/torque.htm
130 newton meter = 95.88 pound foot
Old 09-09-2010 | 08:22 PM
NiteTrain's Avatar
if you google nm to lbs conversion be careful..the first link gives you a wrong number
Old 09-09-2010 | 09:07 PM
antichrist's Avatar
that's why I always use onlineconversion.com, have them my bookmarks toolbar.
Old 09-10-2010 | 09:48 AM
discomedic4's Avatar
Anti provided the conversion factor so you can just do some simple math from there and figure it yourself.
Old 09-10-2010 | 12:14 PM
okdiscoguy's Avatar
I didn't even look at the conversion. I usually have to reverse it because I have a metric dial torque wrench...
Old 09-10-2010 | 12:17 PM
ColoDisco's Avatar
Originally Posted by spike555
whats a torque wrench?
x2
Quick Reply: rear diff pinion nut torque specs
