Remove cats to increase gas mileage?
Guys, I live in a country with no emissions regulation. How much is the impact of removing the catalytic converters in my Discovery in terms of gas mileage? Would it also help to change the exhaust system and put bigger tubes? Any idea?
I was getting very low gas mileage until I replaced the distributor cap. Now, It is better but still need to improve.
Putting new O2's will give you the best result (unless you have a plugged cat). If you put exhaust that has a higher flow, you will need to match the intake and swap out the cam for more lift. The cheapest and easiest thing to do is to cut off your rear resonator and turn the pipe down. I would also pull the silencer trumpet from the airbox. It will be a little louder, but it will improve flow.
I would not suggest pulling cats. If you feel like there is too much restriction, put some high flow Magnaflow cats (or similar) on. You will not see much improvement unless you spend a lot of money on airflow..
on
Depends on how Rover set your emission system up, do you have 02 sensors, if so 2 or 4?
If you don't have any, you might pick up 1/2 or a little more MPG, can't say it is worth it though.
What octane gas are you running? Keep you air pressure up to around 40 PSI and you may pick up a little mileage.
here kitty, kitty...
First off, What year is it and do you know which market it was originally shipped to and sold in? That can make a difference as to what you can reasonably do with GEMS. I'll be crazy and assume it is North American Spec or Rest Of World since you are in Central America...
Second, definitely use a higher Octane gas... you will notice a difference in power and mpg.
