Replacing Rotors
I looked at AB's rebuild kit for the Front and Rear and mad emy own kit using Trevor's website Rovah Farm
(I included each part number per Rovah Farm)
Includes-
4 Joint Washers Gaskets 571752
2 Front Rotors LR017951
2 Rear Rotors LR017953
4 Inner Hub Seal RTC3511
4 Washer Lockers FTC3179
2 Rear ABS Hub Seals ?????
2 Front Brake Pads w/ Hardware
STC9191
2 Rear Brake Pads w/ Hardware
SFP500190
My kit includes all of the above minus the brake pads since I use Auto Zone's that have lifetime warranty so I paid for one set and every time I need to change I just bring the old ones in and get free new ones. Also, I changed the 4 inner hub seals with RTC3511 like many of you have said. My main question is the 2 rear abs hub seals do I need these or is there another part I can get because I disabled my abs.
UPDATED LIST:
Rovah Farm-
2 front brake rotors
2 rear brake rotors
4 hub member gaskets
4 lock washers
4 inner seals (rtc3511)
2 packs of 1 shot grease
2 swivel pin kits (swivelpinkit06)
Auto Zone-
8 wheel bearings (timken set37)
AB-
2 Swivel ball reseal kits
TOTAL with all taxes and shipping: $572.84
Includes-
STC9191
SFP500190
UPDATED LIST:
Rovah Farm-
2 rear brake rotors
4 lock washers
Auto Zone-
AB-
...and I'm surprised AZ hasn't changed the wording of the warranty to "against manufacturing defects" like almost every other parts supplier. I remember years ago when Western Auto warrantied when they wore out, and I thought, "It's too bad fuel doesn't have the same warranty, because then I could get a free tank when it reached empty."
Alright thanks guys
and so get everything for the D90? Can somebody confirm that so I don't get parts I can't use haha. I don't mind switching, I mean I'm getting all these things anyways..
any more info on this?
sorry, the D90 calipers have larger pistons and larger pads and bolt right up. I'm sure you'd need their rotors as well. They bolt in real easy. But the hard brake line needs to be rebent or you can install a new line and bend it yourself. D90 calipers rotors and pads all around. SHouldnt have any issues
