Resetting "Adaptive" Values after IACS replacement.
Ok, so as some might know, I had to replace my IACS after the idle went high.
Easy enough until I went to find an independent shop to reset the adaptive values. They tried to baffle me with bull :poop:. As chance would have it, ropertf on DiscoWeb (http://tinyurl.com/hccqx4g) wrote a program to reset the values about the same time. It works on both Win and Mac. I used an old XP laptop and this: https://www.scantool.net/obdlink-sx/. It worked great. For about 150 miles. Did it again. Lasted for about 300 miles. Did it a third time. Lasted about 1,500 miles. That was three days ago. Think I might get set up with a bluetooth thingy and just hit a button on my phone. Also, I can't rule out some intake, plenum gasket leaks. Wee as they may be. Overall, I am still giddy that I don't have to take it somewhere for this. |
Below are the values from the last three times I reset them.
Just noticed as I pasted that my TPS numbers seem wanky. :confused: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\H. Howard>cd desktop\gems C:\Documents and Settings\H. Howard\Desktop\GEMS>gems com4 reset Connecting to:com4 ............ AUTHORIZING AIR ADAPTIVE VALUE: 43263 FUEL ADAPTIVE VALUE: 25 TPS CLOSED VALUE: .140V RESETTING ADAPTIVE VALUES DISCONNECTING C:\Documents and Settings\H. Howard\Desktop\GEMS>gems com4 reset Connecting to:com4 .............. AUTHORIZING AIR ADAPTIVE VALUE: 48895 FUEL ADAPTIVE VALUE: 19 TPS CLOSED VALUE: .610V RESETTING ADAPTIVE VALUES DISCONNECTING C:\Documents and Settings\H. Howard\Desktop\GEMS>gems com4 reset Connecting to:com4 .............. AUTHORIZING AIR ADAPTIVE VALUE: 40447 FUEL ADAPTIVE VALUE: 22 TPS CLOSED VALUE: .585V RESETTING ADAPTIVE VALUES DISCONNECTING C:\Documents and Settings\H. Howard\Desktop\GEMS> |
This needs to be a sticky.
That is very cool!
I hope ropertf continues to add to this program. |
Much thanks to ropertf - worked for me - idle is back to normal. Only a few min old so hopefully she holds.
I used a mac with VMware virtual machine - win7 64bit with OBDLink SX biggest hangup was the proper dos language proper example: "gems com3 reset" |
I can't get this to work on my Windows 10 Pro computer. Any ideas?
Edit: Tried it on Windows Vista 32Bit and Windows 10 Home as well, still no luck with either program. Just says COM STATE ERRORConnected to:com4 If anybody knows how to fix this, that would be great because I am stumped and really need to get rid of my FMFR and AMFR codes. |
'COM4' is not a constant - you must find out what port the usb is plugged into - under device manager in Win7 - I dont know 10
On this page are the steps I took to get it to work on mine: https://discoweb.org/showthread.php?...ferrerid=26432
Originally Posted by whiskeynipple0088
(Post 607468)
This is in fact configurable in device manager regardless of OS version |
Originally Posted by hrhoward
(Post 607484)
Install driver for scanning cable find port used run program in command prompt by getting to the directory with the gems.exe executable and run "gems com# reset" but every time I do that, nothing happens The program that came with the cable works with my D1 Is there something else that I'm missing or something that I am doing wrong? Thanks in advance. |
