Resetting "Adaptive" Values after IACS replacement.
Old Mar 3, 2017 | 09:26 AM
hrhoward's Avatar
Thumbs up Resetting "Adaptive" Values after IACS replacement.
Ok, so as some might know, I had to replace my IACS after the idle went high.
Easy enough until I went to find an independent shop to reset the adaptive values. They tried to baffle me with bull .
As chance would have it, ropertf on DiscoWeb (http://tinyurl.com/hccqx4g) wrote a program to reset the values about the same time. It works on both Win and Mac. I used an old XP laptop and this: https://www.scantool.net/obdlink-sx/.
It worked great. For about 150 miles. Did it again. Lasted for about 300 miles. Did it a third time. Lasted about 1,500 miles. That was three days ago.
Think I might get set up with a bluetooth thingy and just hit a button on my phone. Also, I can't rule out some intake, plenum gasket leaks. Wee as they may be.
Overall, I am still giddy that I don't have to take it somewhere for this.
Old Mar 3, 2017 | 09:32 AM
hrhoward's Avatar
Below are the values from the last three times I reset them.
Just noticed as I pasted that my TPS numbers seem *****.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\H. Howard>cd desktop\gems
C:\Documents and Settings\H. Howard\Desktop\GEMS>gems com4 reset
Connecting to:com4
AUTHORIZING
AIR ADAPTIVE VALUE: 43263
FUEL ADAPTIVE VALUE: 25
TPS CLOSED VALUE: .140V
RESETTING ADAPTIVE VALUES
DISCONNECTING
Connecting to:com4
AUTHORIZING
AIR ADAPTIVE VALUE: 48895
FUEL ADAPTIVE VALUE: 19
TPS CLOSED VALUE: .610V
DISCONNECTING
Connecting to:com4
AUTHORIZING
AIR ADAPTIVE VALUE: 40447
FUEL ADAPTIVE VALUE: 22
TPS CLOSED VALUE: .585V
DISCONNECTING
Old Mar 3, 2017 | 01:38 PM
ihscouts's Avatar
This needs to be a sticky.
Old Mar 4, 2017 | 05:58 AM
Toran's Avatar
That is very cool!
I hope ropertf continues to add to this program.
Old May 28, 2017 | 01:32 PM
whiskeynipple0088's Avatar
Much thanks to ropertf - worked for me - idle is back to normal. Only a few min old so hopefully she holds.
I used a mac with VMware virtual machine - win7 64bit with OBDLink SX
biggest hangup was the proper dos language
proper example: "gems com3 reset"
Old May 29, 2017 | 12:30 PM
DiscoCam's Avatar
I can't get this to work on my Windows 10 Pro computer. Any ideas?
Edit: Tried it on Windows Vista 32Bit and Windows 10 Home as well, still no luck with either program. Just says COM STATE ERRORConnected to:com4
If anybody knows how to fix this, that would be great because I am stumped and really need to get rid of my FMFR and AMFR codes.
Old May 30, 2017 | 11:39 AM
'COM4' is not a constant - you must find out what port the usb is plugged into - under device manager in Win7 - I dont know 10
Old May 30, 2017 | 01:14 PM
hrhoward's Avatar
On this page are the steps I took to get it to work on mine: https://discoweb.org/showthread.php?...ferrerid=26432
Old May 30, 2017 | 04:18 PM
DiscoCam's Avatar
Device manager showed com4 as the usb scanner
This is in fact configurable in device manager regardless of OS version
Old May 30, 2017 | 04:23 PM
DiscoCam's Avatar
Followed the same instructions but everything I try doesn't get it to work. I don't know why, maybe I'm missing something. But from my understanding this is the procedure:
Install driver for scanning cable
find port used
run program in command prompt by getting to the directory with the gems.exe executable and run "gems com# reset"
but every time I do that, nothing happens
The program that came with the cable works with my D1
Is there something else that I'm missing or something that I am doing wrong?
Thanks in advance.
