Riddle me this. Light question
Old Nov 18, 2011 | 09:46 PM
Discolife's Avatar
Default Riddle me this. Light question
Fog light bulb for driverside rear is out. Do I have to remove the jump seat to access? If so how the heck do I do that.
Bumper lights they bulbs but no worky. Are the grounds for the bulbs sequential?
Most importantly How the heck do you get in the front fog lamps? Found the service info for front fog lamps.......may I say what a pain in the ***!
Old Nov 18, 2011 | 09:51 PM
Yes. Unbolt them.
It is common for the bulb sockets in the bumper to go bad, remove the bulb and check for corrosion.
Buy these in pairs.
Bulb Holder Single Filament | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
Also might need these, I did.
Bulb Holder XBP100180 Harness Repair Kit - RoverParts.com - Land Rover Parts & Accessories
Old Nov 18, 2011 | 10:15 PM
Discolife's Avatar
Spike, so your saying its likely corrosion? If so Ill clean and test.
On the jump seat question I have to unblot them! That blows! LOL
Originally Posted by Spike555
Yes. Unbolt them.
Buy these in pairs.
Old Nov 18, 2011 | 10:24 PM
EricTyrrell's Avatar
Nope sorry, THIS is a pain in the ***!
Riddle me this. Light question-img_1855.jpgRiddle me this. Light question-img_1856.jpg
Old Nov 18, 2011 | 10:27 PM
Yes it does blow for the rear seats.
I was going to swap them over from my donor that I bought last summer but decided not to because of this as well as storage space in the back of the truck.
Remove the bulb holder from the truck and inspect it for corrosion on both ends, where the bulb goes as well as where it plugs into the wire harness.
If you dont have mudflaps the bulb holders get full of road grim, water, etc.
I've replaced mine so many times it was ridiculous.
I have since made my own mudflaps so we will see if they last longer.
Old Nov 18, 2011 | 10:41 PM
Discolife's Avatar
Im thinking a silicone moisture spray sealant I have Ill try on them too. used it for wiring that will see forging on my jeeps before. Its sprays on like a clear rubber bedliner.
Old Nov 18, 2011 | 10:47 PM
I've tried everything to seal them up, but for some odd reason they always get water in them.
Down by the river - YouTube
Old Nov 19, 2011 | 06:29 PM
Discolife's Avatar
looks like I need a socket and plug as the ones are corroded, Fog lamp was nothing more than a corroded connector
Old Nov 19, 2011 | 07:34 PM
psykokid's Avatar
If you need a front fog lamp, i have a spare that came with my truck. Cover postage and it's yours..
Old Nov 19, 2011 | 07:39 PM
tweakrover's Avatar
You don't need to remove jump seats to change bulbs. There are panels that remove to get to the lights, it is super tight but its doable, may be easier to remove the 2 wing nuts that hold the light assembly in and change them that way.
