-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   is this the right bearing? (https://landroverforums.com/forum/discovery-i-39/right-bearing-45246/)
cationmoted Nov 17, 2011 09:05 PM
LAND ROVER PARTS - PRO LINE WHEEL BEARING 90/110, R/R & DISCOVERY I
i need to replace my wheel bearings. i was wondering if this was the right bearing to buy?
also if i am doing both my fronts then that would be 4 bearings right?
would i need anything else or can i get away with just buying the bearings and grease?
if the wheels have been wobbling for a significant amount of time could that have damaged the bearing ring?
adigerol77 Nov 17, 2011 09:14 PM
Land Rover Discovery Series I wheel bearing part numbers per AntiChrist
Timken SET37, SKF BR37, FAG KIT3 or National A-37
Hub seal part number- RTC3511 (double lip seal)
From the sticky page.
Spike555 Nov 17, 2011 09:17 PM
Here is everything you will need to do one side.
So you would need 2 of these kits.
Wheel Bearing Rebuild Kit for Discovery I | Land Rover wheels, tires, hubs, axles
If you go to the DI tech section you can find just the bearing part numbers to buy them locally.
But then you still need to order the seals and gaskets.
If you are lucky you can reuse your seals and use RTV on the hub flange.
But you wont know until you take it apart, and then what if you cant reuse your seals?
antichrist Nov 18, 2011 08:09 AM
I wouldn't even try to reuse the old seals, except maybe the inner seal since you have to remove the stub axle to replace it.
You can get the RTC3511 seal from RovahFarm.
These are the ones I use.
Get the bearings locally and just order the seals and 3 or 4 lock tabs. Gaskets if you want.
Danny Lee 97 Disco Nov 18, 2011 12:20 PM
You may also want the spanner wrench to remove the locknuts unless you have a socket that big. RovahFarms has two different ones on their page.
gring1961 Feb 26, 2014 11:39 AM
how did you find changing wheel bearings need to do mine but a bit worried
CUpgt Feb 26, 2014 03:32 PM
Get a 52mm socket and a decent punch to drive out the old races. It's an easy job, just messy
calebbo Feb 26, 2014 08:49 PM
There's a thread in the sticky. Check it out https://landroverforums.com/forum/di...earings-44462/
TOM R Feb 27, 2014 04:54 PM
Timken on amazon 14.60 each with race , free shipping
TOM R Feb 28, 2014 03:55 PM
What brand is the hub seal # listed ?
