RR classic and D1 parts interchange??
Old Feb 14, 2011 | 05:25 PM
AKdisco's Avatar
Default RR classic and D1 parts interchange??
I just got a free 89 Range Rover, it has a 3" coil spring lift on it. I was wanting to throw the coil springs from the rangie under my Disco, they are the same correct?. I know the disco is a tad heavier but thats ok, I dont need the full 3" of lift, even a 2.5" boost will be nice AND IT WAS FREE. Also, they use the same axles etc etc right?. Just wondering if I should keep this thing around for spare parts??
Old Feb 14, 2011 | 05:27 PM
Yes, yes and yes.
Old Feb 14, 2011 | 05:53 PM
jafir's Avatar
The 89 RRC is going to have 10 spline axle shafts and side gears.... but they can be upgraded to the newer style.
Old Feb 14, 2011 | 05:55 PM
jafir's Avatar
Oh! also, does the RRC have a regular u-joint in the back? If so, you can use the driveshaft and pinion flange to upgrade from your rotoflex, assuming it isn't a LWB... not sure when they started making the LWB...
Old Feb 14, 2011 | 05:59 PM
AKdisco's Avatar
Default hey
Its not a LWB, its one of the shorty's.
Old Feb 15, 2011 | 07:09 PM
demonlarry's Avatar
I'll double your money on it, if you're interested.
Old Feb 16, 2011 | 12:16 PM
AKdisco's Avatar
Default haha
Ok........Raise me 100 bucks and its a deal......without lift springs of coarse
Old Feb 16, 2011 | 01:45 PM
jafir's Avatar
does it run and drive? I'll give you $99 ;-)
Old Feb 16, 2011 | 01:48 PM
Chris-bob's Avatar
You better hope your North and not in Ketchikan. If you are in Ketchikan, I'd like a look at that RR.
Old Feb 16, 2011 | 01:50 PM
AKdisco's Avatar
Default hey
Im in Anchorage my friend.
