running light failure
Old Jul 10, 2011 | 09:10 PM
Harris97's Avatar
8th Gear
Default running light failure
I have an issue with my front running lights. The blinkers work but only my headlights are lit up on the front. I've checked fuses nothings wrong there any ideas?
Old Jul 10, 2011 | 09:50 PM
adigerol77's Avatar
Do a search on the forum, there was something similar to this about 2 weeks or so ago. It's more than likely your turn/headlight column switch but there are other signs.
Old Jul 10, 2011 | 11:05 PM
fishEH's Avatar
No, that's normal for D1's. There are no amber running lights. Turn on your parking lamps and you'll get: city lights IN the headlamps, and red taillights. Turn on your headlights and you'll get city, headlamps, and taillights.
I think you can put Defender dual bulb sockets into the front blinkers for always on amber parking lights. I looked into it from Rovers North and it wasn't worth the $$$.
Old Jul 10, 2011 | 11:12 PM
adigerol77's Avatar
There are no front "running lights" per se. On the side caps of the front bumper there are the turn lamps that also do light up as running lights but nothing in the front.
Old Jul 11, 2011 | 05:15 PM
Harris97's Avatar
8th Gear
Turn lamps only light up as I turnthe signal on
Wayne
Oct 2, 2020 12:10 PM
binvanna
Jan 9, 2013 04:17 PM
marlymarl
May 28, 2011 10:34 PM
adam123
Mar 23, 2011 07:56 PM
wilbur07
Freelander
Jul 18, 2007 09:14 PM
