Security code for radio doesn't work.
Old Nov 3, 2011 | 05:59 PM
hh65flyer's Avatar
Default Security code for radio doesn't work.
Making some progress on little things and thought I would see if the radio worked in this beast. So it's asking for the code...lucky me I have the owner's manual complete with instructions and ID cards.
Well the code doesn't work. it just beeps after entering the fifth digit. I also found a hand-written code in the book but that didn't work either.
Is there a hidden place to find the code or procedure to recover the code somehow? I've searched the forum but couldn't find anything. Thanks!
Old Nov 3, 2011 | 06:45 PM
Sounds like the radio has been replaced with a used one and you may be out of luck. There is a possibilty that the battery in the radio is bad or low on voltage, might try and leave the radio powered up for the next few days and see if it will recharge.
Old Nov 3, 2011 | 07:07 PM
hh65flyer's Avatar
Well I know it sat for almost a year with a flat battery so I guess I could try that. Just put the key in ACC and turn the radio to on?
Old Nov 3, 2011 | 07:17 PM
EricTyrrell's Avatar
Mine took quite a few tries and lots of waiting before it worked.
Old Nov 3, 2011 | 08:21 PM
bradical's Avatar
If you enter the wrong code it will "lock" itself up. After you try to it and it fails, turn the key to acc or run and let it sit for awhile. I let mine sit for 30min. Went back and carefully punched the code in and it worked.
Old Nov 3, 2011 | 10:21 PM
ihscouts's Avatar
Yes, just turn the key to accessory (position II) and leave the radio on. Also every time you enter the code and it doesn't take for whatever reason it adds time to the wait before you can enter it again. Best just to leave it on for an hour or more and re-enter and it will work like there never was a problem......it's the dumbest thing I've ever witnessed.
Old Nov 4, 2011 | 07:26 AM
Better yet don't drain the truck battery by leaving the key on, let the radio battery charge while you are driving, may take a few days if the battery will take a charge.
If you still have problems, then call the link in my signature section and talk to the radio people.
Old Nov 4, 2011 | 07:37 AM
Long Haul's Avatar
If it makes any difference I had a code on top of the radio that worked for mine. I had the same problem on mine, when I went to replace the radio it had a LR sticker with the code stamped on it. Punched that code in and it worked right away.
Old Nov 4, 2011 | 08:23 AM
hh65flyer's Avatar
Thanks guys, I'll let it stay on today with the battery charger plugged-in.
Long Haul, that would seem to defeat the purpose of the anti-theft code if they printed it right on top of the case! Certainly worth taking a look at though...thanks!
Old Nov 4, 2011 | 08:30 AM
Long Haul's Avatar
Yeah my thoughts exactly. I had the original card in the owners manual then there was a hand writen code under it, I tried both after no luck for a couple weeks I was going to go with an aftermarket radio and bam there was a code on the case. I guess I got lucky.
