Sensor ring
![Angry](https://landroverforums.com/forum/images/icons/icon8.gif)
I cannot remove the sensor rings from my old rotors, now I cannot find the sensor rings on line to order them. Do they have a different name? Where, how do I look for them? Yeah, I know I can wait until Monday and ask someone on the phone and keep my car on jacks for a week.... Any help will be appreciated.![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
The ABS ring is removable,not built into the rotor. You will want to find used ones,if you can not get them out,(e-bay or roverguy.com), as new ones are VERY expensive.
BTW, I assume you know there are 5 locknuts holding it on? On the face of the rotor, facing the hub assembly.
http://www.roverparts.com/Parts/FTC1379.cfm
I just did that job this morning, putting new rotors and calipers on the back. The nuts were just lumps of corrosion, nothing even to grab on to, really. I zipped them off with a cutting wheel, and unscrewed what was left of the studs out of the exciter with vice grips - actually could have used channel locks, they came out easy. $6 at lowes for new studs and nuts, fairly easy all around.
Plusit fit 32" tires with only a little torsion bar crank.
