Spray paint roof and hood
you will get a million responses on how to do it. but i say rattle cans from wal mart, sandpaper, painters tape and some kind of cleaner is all you need. although there is another option that you can use vinyl that i know has become very popular. check it out http://www.unfinishedman.com/how-to-...lack-for-cheap
Heat. Without the heat padding under the hood the engine can literally bake off the factory paint. (this happened to my 97) So I'm guessing you would want to make sure your using a high temp rated paint. Paint it with engine paint would be my guess, but I have no actual experience with trying it so take this with a grain of salt.
Hey man I removed my hood and took my time taping off the hood very very carefully. around the corners I slowly made the angle by putting the strips of tape over one another until the curve was complete. I then took a Xacto knife and sliced the tape to make the curve neater and get any angles out of it. Sanded it down with I think 400 grit sand paper until all blemishes were gone, then did it again. Wiped it down with soapy water to get the dust off. Someone wrote that using alcohol wipes or rubbing alcohol works well also.
Painting: this is where I messed up the most. So the technique is to put as many light layers on as possible. Then gradually adjust your spraying to make the coats even. I suggest going from the front of the hood to the back rather then from side to side. Reason being is the curve of the hood from left to right gives you and uneven appearance. All in all it looks awesome! I plan on doing my hood as well sometime soon. That's going to be a bitch though. I used Krylon Satin black indoor outdoor rattlecans. This was about a month ago it still looks great! I didn't put any clear coats on top. I'll just repaint it later when it starts looking bad.
"Can you see the light?"
Nope just make sure it is FLAT paint with no gloss or shine. The whole point of the black-out on the hood is to reduce glare back into your eyes at night especially if you have or plan to have lights on your roof.
Even with flat paint it still seems to be a glare with roof lights, but normal driving it does take a lot of oncoming cars glare away with a flat paint surface on the hood
