Starter broke off the engine
I have a 98 Discovery. Was driving 70 mph when I heard, and felt, a thunk immediately followed by black smoke. Pulled over to see a puddle of what I thought was oil. After tow home I saw the starter completely off the engine block caught up in the suspension.
Both flanges completely snapped. Anyone know what could cause such a thing to happen? Thanks.
what remains of the flanges are still bolted to the block. They look secure but I'll double check. Is it possible the starter engaged while driving and once the gear hit the flywheel it pushed it out?
I dont want to simply replace the starter before finding out what caused it to happen.
I think the teeth would be ground to hell if the starter engaged while you were on the freeway. Check the teeth on the flywheel too.
I'm sort of at a loss as to what could have happened. Mike could be right about the loose bolts ; every time you started it, the starter was jerking against the flanges until they just got weak and broke.
