Stereo Head Unit upgrade
Yep, so the security radio code does not work, even after confirming with Land Rover USA the cross referenced s/n of the radio, the security code is correct. They say I need a new unit.. fine.
I'm replacing the radio altogether.. problem is, I cannot find any useful information to help me figure out what these wires are. I'm doing it myself, because frankly, I don't have the extra $200 to shell out to Best Buy for a quasi-professional install. I am competent enough to do this myself, but I need some help with wire identification.
The two black wires came out of back of radio that are labeled "Main" and "Sub", which I imagine is for the amp and rear subwoofer? The wires themselves are labeled "LH DIV" and "RH DIV" respectively. But what is the blue cable? Antenna?
Thanks for the reply...
The CD changer would be under the passenger seat, correct? I looked, and it is not present. So.. I don't have to worry about the blue connector, just set it to the side I suppose.
What about the two RCA-looking connectors? I searched another forum, but that led me to a dead end thread.
Those two black RCA-looking cables are for the antenna (truck has two in the side rear glass). The blue is the CD Player cable which should be found under the passenger seat.
Look for a "Metra 70-9400 Radio Wiring Harness for Land Rover/Discovery" to hook up aftermarket head units to the factory amp.
Oh, the amp is in the passenger footwell. If the new head unit has an amp, you'll need to bypass the factory amp or run new wires to the speakers. There is a small amp attached to the subs in the rear door to power them.
Yep. Took me a minute to find it too! The CD changer is under the passenger seat. The subwoofer amp is nowhere to be found, I think it's been removed. I'm going to do my own thing anyway so it doesn't matter.
Next big question: how the heck am I supposed to connect the antenna?
