Swivels off, pics and some questions (kind of long)
Just letting you know that we censor all of the F****ng bad words and try to keep it somewhat clean...
Bringing this back...
Is there a write up on thrust washer and needle bearing replacement?
I do a lot of press fit wheel bearings, and often times when hammering the hub out of the bearing, the inner race comes out with the hub and needs to be cut off. Im assuming the same thing is required but wanted to verify.
My bearings are questionable as there is a bit of rust on them and more importantly I want to replace the seal behind it.
Lastly, how do I install the new bearing? Press, hammer and socket, drop in?
Yep OO. Hardware for the hub nut socket, it's about the same size as an electric hot water heater element socket. If you can find one with a 3/8" socket wrench your way ahead of everybody else cost wise. AB has them too.....fit's on a socket wrench for the torque spec.
I just removed my axle seals and let the 90W slosh side to side to oil the CV's. Cheap and works like a champ. I have the swivel oil drains too, early 97....
