TF Med Springs too soft....
#31
Old Man Emu Coil Springs -- EE -- Expedition Exchange Incorporated go here, scroll down
On a side note I am going to pick up a set of 5" RTE's this weekend if anybody wants to call dibs on my less than 6 month old Terrafirma HD's
#35
#36
#37
You know, it will all depend on the constant load. The MED springs are good springs no doubt. From driving more by myself, unloaded, the springs become a little bouncy in the rear. Nothing at all to complain about, It is just my driving style that introduces these little issues. For a daily ride, it is perfect. Fully loaded, it rides as smooth as can be......a really nice, comfortable too.
My complaint was more inline of height and wheel arch issues. I was wheeling with a full load of passengers and gear, from bikes to filling up my roof rack. Oddly, when both sides of the rear compress, the rear right tire touches the lip of the arch.....which cut a few lugs....but when unloaded and when it does side to side articulation....no touching at all....????
To sum it up...you will not go wrong with those springs. If you go wheeling, just pay attention to the sway bars. I found you can bind up the stock rear pretty easily....when articulating.....
#38
#39
Obviously the rubbing of the oversized tires has to do with the rubbing as does where the bump stops are located, rim offset, and obviously spring rate.
rchrd0413
04-22-2014 02:18 PM
hayleyspop
01-10-2014 08:50 AM
