Thanks to everyone!
![Thumbs up](https://landroverforums.com/forum/images/icons/icon14.gif)
So I bought my 95 Disco a couple weeks ago and immediately started going through my normal routine of parts after buying a used car. It leaks ALOT of pretty much everything except coolant. Nothing major I guess I will just top everything off until something really goes wrong. But I have noticed that I had most of the issues that everybody on here is listing. Bad rollers on window regulators, bad window ecu, high idle issues, BIG oil leaks, stuck diff shifter, and probably a few more. But thanks to everybody on here and the tech sticky section, I have been able to correct much of it with minimal $ spent. I still need to handle the stuck diff but no big deal at this time because I'm not planning on offroading until I take the hubs apart and check bearings and seals first. I just wanted to say THANKS! And I look forward to asking for more troubleshooting help on a regular basis if what everybody around here says is true.
