Trans Filter
Old Dec 27, 2010 | 11:24 PM
kenk's Avatar
A small funnel and the dipstick tube to fill. The only dumb question is the one not asked.
Old Dec 30, 2010 | 09:39 AM
Analogkid's Avatar
Guys Im getting conflicting reports from various sites on type of Trans fluid. Anything from Dextron to ATF4 any suggestions???
Old Dec 30, 2010 | 09:48 AM
kenk's Avatar
By LR's standard dexron 3/mercon is called for. But if you look up newer dexrons, alot of them are backwards compatibale with dex 3. Some are not, gotta be careful. But I may offer, when I did my filter, I filled with a newer dex and eneded up draining and going with old school dex 3. In mine, it like it better
Old Dec 30, 2010 | 01:37 PM
Analogkid's Avatar
thanks Kenk
Old Dec 31, 2010 | 02:42 PM
Analogkid's Avatar
Lucky for me ALL and I mean all the bolts and plugs are rusted in place. My D1 has 83k on it and I would guess the fluild may have been changed at some point but the pan never dropped. The cross member bolts are now soaking in PB Blaster as are the pan bolts and the drain plug. 2 hours of soaking and tapping with a hammer did nothing. A long overnite soak and maybe some heat tomorrow will do the trick.
Old Dec 31, 2010 | 02:58 PM
Long Haul's Avatar
I broke every bolt off on my crossmember mounts when I did it. I just picked up all new bolts at the local hardware store.
Old Dec 31, 2010 | 09:11 PM
richiec's Avatar
Smile thanks
i am just going to change my tranny filter on my 2003 disco and i saw your post with great detail and pictures this is a great site
thanks richiec
Old Jan 1, 2011 | 07:35 AM
Analogkid's Avatar
I hope most stores are open today since its new years!!!
Old Jul 9, 2011 | 11:19 PM
errose2002's Avatar
so only 5.25 quarts of fluid? I put in 7 quarts and it shows over filled by a lot. The manual says that it takes 9.5 quarts. I guess that includes the torque converter too then?
Old Jul 10, 2011 | 08:48 AM
The 9.5qts is if you do a complete rebuild or it is a brand new "dry" transmission.
You never go by the book capacities when doing this type of work, you just buy more fluid than you think you will need and the add only what YOU actually need and NOT what the book tells you you MAY need.
So after changing the trans filter you would add 4 qts, start the engine, shift through all the gears and check the fluid level.
Add more if needed.
Then once it was within the safe range drive it for a day and then check the fluid level again.
You are going to need to drain some of that fluid out.
