Transfer box will not go into gear
I wondered if it needed to be grounded or something. The only thing about bolting it down is I know the TC linkage needs to be adjusted and I can't do it with the shifter bolted down.
I'm talking about the Auto trans shifter (only going into reverse). Sorry it's a bit confusing because I've had trouble out of both. The Auto trans shifter doesn't need to me adjusted but the transfer case does. If I install the auto shifter it will make it a PITA to adjust the TC shifter.
i would bolt down the auto trans shifter and see if it resolves the issue, be sure while everything is apart that you clean and grease all the parts and pivot pins in the tc linkage and tc shifter
Yes sir, did that already but I might slather a bit more on. That one part that hooks to the lever wants to bend easy. I might take it to my welder and get it reinforced.
Mine is in pretty good shape. The top leaks a bit and there is a little rust under the back seat floor pan but just a little spot. Other than that it's in good shape.
Well I've been driving back and forth to work this week and it runs better and better the more I drive it (running fresh gas and injector cleaner). I've found out it smoothes out over 60 mph so at about 58 mph it vibrates some. Other than that it's pretty smooth. The brake light, two turn signals and two running lights weren't working. Turns out all but one didn't have a good connection so I glued a piece of sandpaper to the end of a pencil eraser, cleaned them up and put battery terminal lube on them. All work good now except for the one running light (needs bulb).
I need to find that vibration now.
