trick to differentail drain plugs?
Is there some trick to the drain plugs for the dif? I have tried spraying them with penetrating spray, hitting the breaker bar with a hammer, and putting an extension on the breaker bar. All I achieve is the sensation that I am about to strip the plug. There is no telling when the gear oil was last changed, and I would really like to get it done. Any suggestions?
they are reverse threaded, or are you just referring to orientation? Also is there another way to heat them lacking propane torch(or any torch for that matter)? Yeah, i already have the fill plugs out, though I have run into the same problem with the transfer case fill plug as I am having with the drain plugs for the diffs. i am starting to wonder if this is my idiocy or the previous owner over torquing them(probably the first, but my ego prefers the second option).
on
I used PB Blster for two or three days in advance, then used a half inch drive 18 inch long breaker bar from Harbor Freight. I also have piece of scrap black iron pipe about 40 inches long if I need extra UMPH to break it loose. A slow steady pull with a longer lever arm usually does much better a high shock blow such as a hammer application.
I have even used a foot to push the longer breaker bar if I cannot pull or push by hand. What you want is to develop the most Foot-Pounds of Force. The longer the lever arm, the greater the force you can apply in a steady manner. I have learned over the years to avoid smashing and breaking things.
You may want to cheat and take it to a quick lube for their "4x4" service, it usually runs around $60.
Let them break everything loose and change all the fluids, then in a couple of weeks you change it again yourself.
If it has never been changed before this would be a great way to flush everything out and save yourself the headache.
Plus if they break it they will replace it.
