Turn signal/marker mod
Another post rekindled my possible desire to turn the front turn signals into marker's as well.
BUT, I have some questions for hopefully someone who knows more about 12VDC systems than myself.
So the idea is to buy a couple of these and some pigtails.
Bulb Holder Dual Filament (XBP100190 Same Fit As Part # XBP100190 ) - Land Rover bulbs from Atlantic British Grab a dual filament bulb and wire it up. Basically tap into the existing side marker light and wire up the other filament.
Help me out here, will this work. Will my lights go crazy? Will the marker filament stay lit and the signal filament light up when the turn signal is applied? Will that even work?
Here's a super simple(and crappy) drawing of what I'm thinking. And I've attached a pic of basically the same thing.
True. Part of my desire to do this mod is because I'm removing and sealing off the holes for my City lights. Those damn holes always open up and the lights never end up working anyway. So my thought would be that when you turn the headlight stalk one click then the marker light in the turn signal lens would light up.
Fish I am gonna do this, you need the bulb holder and 3 wire pigtail that goes with it from range rover, they fit our lens
You should transfer the ground and + from current turn signal hooking the + to the high bright side of dual filament, then take the + from the marker and add to the low side of the new socket, the ground from the old side marker is just extra
IMO this should do it, if the signal flashes fast I guess can try a HD flasher?, when I do my rear bumper I plan to delete the bumper lights, I currently have a fast flash on the pass side from smashing the bumper
On my dodge truck I went to all led, started flashing fast just swapped in the HD flasher problem solved , don't know why it would not work the same on rover
Cool. I'm in too. Tillery gave me a quote but I'm gonna try Paul first, mainly just because I like him better. LOL. I already have the LED flasher from when I installed my rear bumper so I shouldn't see any fast flash.
I actually like the City lights too. However for some reason the plastic/fiberglass hole for them in the headlight housing always seems to start breaking apart and the socketsbdont for right. I'm gonna pull the sockets and just silicone some blanks over the holes. Done.
