Voltage Drops When Running
Old Jul 7, 2018 | 08:57 AM
caniwi's Avatar
Question Voltage Drops When Running
Hello all. I hope I'm not repeating any previous threads; I've had a look and don't see anything similar to my problem. I had an erratic rev counter with the needle either not working or bouncing. From what I've read this is usually an alternator problem. The truck was running fine so I just left it until I started having more issues. I then replaced the alternator cause it is a quick part to change and the old one was definitely looking like an original part. I had about 11.5 volts between the battery terminals with the engine shut off but the voltage would drop to ~10v when running. The new alternator does the same thing so obviously I don't have a problem there. Any ideas? I'm not sure where to "start" here (sorry, bad pun).
Old Jul 7, 2018 | 07:51 PM
ihscouts's Avatar
The battery should be no less than 12.6VDC with motor off, running should be 14.2 +/- .2 VDC. I'd have the battery checked for a dead cell. Your readings indicate the battery is about to go kaput. Hope you saved your original alternator..... you can rebuild it (bearings, diodes/rectifier) yourself and it will far outlast any parts palace rebuilds. Probably wasn't bad to begin with......
Old Jul 8, 2018 | 09:53 AM
caniwi's Avatar
I was assuming the initial low battery voltage was due to it not having had a proper charge, but it would be awesome if it was as simple as a bad battery. It's not that old but who knows?
Old Jul 8, 2018 | 10:34 AM
ihscouts's Avatar
I would have the battery checked. If it is the battery charge the new one to 100% before installing/using.
Old Jul 8, 2018 | 03:39 PM
Clay Stanley's Avatar
have you checked the 100amp fuse?
Old Jul 9, 2018 | 04:41 PM
caniwi's Avatar
Yep the 100a fuse is good
Old Jul 10, 2018 | 12:07 AM
jimvw57's Avatar
A shorted battery cell will draw down the running voltage.
Old Jul 10, 2018 | 05:43 AM
caniwi's Avatar
I will have to get it looked at by the local mechanic. I have just a basic dmm that won't tell me much about the battery.
Will come back with the results!
Nov15
Jan 10, 2024 05:01 PM
gravityjunkie
Feb 26, 2016 06:38 PM
J P Cook
Jun 4, 2014 09:40 AM
Rover De Land
Aug 21, 2012 05:29 AM
99landroverdisco
Jun 2, 2009 04:53 PM
