-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Water puddle = sputtering (https://landroverforums.com/forum/discovery-i-39/water-puddle-%3D-sputtering-80654/)
dsmeddy Aug 21, 2016 08:18 PM
So..... I ran through a Water puddle today which shot water in many directions. Once I got through it, the Disco started sputtering and not wanting to do anything above idle rpms 700ish. I pulled over and lifted the hood and found the entire top of the engine completely dry. I put the vehicle in park and it idled just fine. When I gave it some throttle it just kept sputtering. 10 minutes go by and eventually all things went back to normal. I imagine something dried out within that time.
My question is.... What wire connection or what could've gotten wet (probably on lower 1/2 of engine) that would of caused this? All top part of engine was dry.
Many thanks
fishEH Aug 21, 2016 09:01 PM
Did you check your airbox/MAF?
dsmeddy Aug 21, 2016 09:09 PM
Air filter intake was dry and all hoses dry on top of engine as well as the ignition coils dry.
97' D1
XCELLER8 Aug 21, 2016 10:56 PM
two things come to mind....the crankshaft position sensor ( or the cracked wiring to it) drivers side lower rear of the block, and also the fender mounted ECU....strategicly located over a rust hole on the passenger side front fender, it may be wet inside ....you can remove it and have a look...then seal it back up
dsmeddy Aug 22, 2016 10:36 PM
https://cimg8.ibsrv.net/gimg/landrov...92faf1f776.jpg
What is this dangling? The crank sensor connection??
XCELLER8 Aug 23, 2016 10:11 PM
the wire connector to the crankshaft position sensor plugs directly into the sensor, its on the lower part of the engine block, at the rear of the engine ( where the flywheel is) and usually has a tin heat shield ( bwhahahhaa ) covering it....the wires to it get heat baked and the insulation crumbles off allowing water to short it out .... google the sensor for a pic of it
this looks more like an O2 sensor connection ?
