-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Water pump Gasket Sealer Question (https://landroverforums.com/forum/discovery-i-39/water-pump-gasket-sealer-question-46192/)
Travelor Dec 26, 2011 12:25 PM
Hi Guys,
Going to be removing a bad water and installing a new pump today -
The question:
Do I need to use a gasket sealer along with the gasket that came with the new pump?
Always appreciate any and all input..
Trav...
Savannah Buzz Dec 26, 2011 09:00 PM
1 Attachment(s)
I used a very light application with mine. See atached page from RAVE, in typical Roverspeak, it is called a "joint washer", see #5 on drawing.
Danny Lee 97 Disco Dec 26, 2011 09:05 PM
Isn't that a gasket? So did you just apply sealant with no gasket?
Travelor Dec 26, 2011 09:41 PM
That is why I am asking - I read the RAVE before - the same section - It doesn't mention anything about using a sealer.. and the gasket I have is paper - oil wouldn't work - in my mind at least..
Trav...
Savannah Buzz Dec 27, 2011 09:08 AM
Thin RTV or Hylomar (spray if you can find it). You are holding the gasket in position on a vertical surface for assembly, and it is paper thin (oil just holds it). Can also be done with Oklahoma grade full strength RTV if no gasket around, but gasket is the best way.
wheelgarage Dec 27, 2011 11:03 AM
I always use a thin layer of ATV, black or grey...
In regards to Hylomar, I recall when that stuff came out. Not too sure if the formulation has changed, but I never had success using it when I rebuilt a few rotary engines, always had issues with curing. The new ATV's and the good'ole Permatex sealant will always do the job....
sideburns Dec 28, 2011 05:56 PM
I would use the gasket only, no sealer.
Jake1996D1 Dec 29, 2011 12:10 AM
Same! I didnt use any on my last one IIRC just a little bit of grease to get the gasket tacky enough to stay in place while mounting the new pump. They also sell those single shot t-stat and water pumper sealant packets at most auto parts stores if you go that route.
Chris-bob Dec 29, 2011 03:39 PM
I used RTV applied thinly with an acid brush when I did my water pump a few months back. Just enough to cover the gasket on both sides.
