Weird Clanking Noise
This has been going on for a while.
It sounds like washers hitting each other..like rattling-metal sound when i hit bumps. its coming from the front.
My shocks are tight as they can be with new poly bush. New tie rods that are perfect.
New wheel bearings ( they are no movement in the wheel to indicate that its a bad wheel bearing)
What gives..its coming from the front for sure. Could it be the panhard bar?radius arm? its something that is definetaly a moving part thats making like a washer to washer hitting noise
When the front suspension gets muddy..the noise goes away but the dirt eventually leaves and the noise is back
No adverse steering or vibrations..just noise
I'd take a look at the panhard rod (or track bar - whatever you prefer to call it) bushings and the axle end of the radius arms. Use a small pry bar to wiggle/move the radius arms - if you have a busted bushing, you should see it this way.
They're rubber, so there's going to be some movement. But if easily moves from side-to-side, then the rubber is likely torn or the rubber is very soft/worn out. It may be your problem.
