Weird rim issue
So on my new to me Disco, I took it down to the local tire shop for a new set of shoes. 4/5 went on great, the 5th one... not so much. They blew up 4 tires trying to get it to seat on the rim. The rim itself has an extra lip on the inside of the barrel, and it was causing MAJOR issues. They have the rim at the shop still, as I had to get back to work (2.5 hours there!) Other than sourcing a new rim, what are my options? Grinding down the lip? (it has a hard edge, a couple mm thick)
Did they lube it up? Soapy water? Maybe something like this: Murphy's Euro White Tire Mounting Paste Alloy Wheel Mount
Yup, like I said, all the others were fine, this one, the lip seems like it's higher, more pronounced, and just wouldn't let the tire slip on. It literally blew the sidewall out in 2 spots. The poor guy airing it up about **** himself.
And yes, it had a tire on it before, stock 16" alloys. They lubed it up like mad, and all 5 guys tried mounting a tire on it, since the first guy said he was done with it, and went to lunch
Lip is to keep tires on bead when aired down, I had some trouble getting my tires off but no issues mounting them
I always do the tire soap on tire bead for mounting
