Well, this wasn't supposed to happen!!
Old Mar 22, 2014 | 10:02 AM
wrongway1's Avatar
Default Well, this wasn't supposed to happen!!
Alright, it's cold & I shouldn't have been working on my disco, but decided to replace the battery ground & positive wires today while I was replacing the 4th alternator under warranty. Well, I seemed to have snapped one of the cooling hose nipples off of the expansion tank trying to "worm" the negative cable out. Is there a way to bypass the expansion tank till I get a new expansion tank Fedex'd to me? Dumb, Dumb, DUMB!!!!
Old Mar 22, 2014 | 07:59 PM
TOM R's Avatar
Plug the hose and run a bolt into the tank and leave the cap loose?
Old Mar 23, 2014 | 07:33 AM
wrongway1's Avatar
Super glued it back together & then ran 3 more coats of super glue over top of that before baking it in the oven. Drove it about 3 miles with out it leaking. Hopes aren't that high it will hold, but will get a few machine screws & rubber washers on your suggestion.
Old Mar 23, 2014 | 09:45 AM
TOM R's Avatar
Just be sure to not pressurized the system
Old Mar 23, 2014 | 09:50 AM
jimvw57's Avatar
I have used a product in the past that is a super glue type of stuff with a 'welding powder' additive. It goes by the name Rapid Fix and does an fantastic job of holding things together. You use it like regular super glue and then add the powder to reinforce the glue joint, and add more super glue.
I have found it locally at NAPA and auto repair stores.
wrongway1
Jan 14, 2020 02:46 PM
ICECREAMEATER
LR4
Jan 30, 2013 05:23 PM
ICECREAMEATER
Jan 18, 2013 05:30 PM
jacumja
May 5, 2011 09:03 AM
seanpage86
Jul 8, 2007 11:27 AM
