What doesn't work on your Discovery?
Old May 12, 2013 | 04:08 PM
Sam95disco's Avatar
Default What doesn't work on your Discovery?
Mine, the door locks and cruise control.
Old May 12, 2013 | 04:59 PM
fishEH's Avatar
Cruise Control hasn't worked in years.
Old May 12, 2013 | 05:45 PM
SSL9000J's Avatar
Cruise control, rear sunroof, (sealed with silicone by PO, probably leaked at some point,) ABS (I disabled it,) rear passenger window control. (Works from the console but not from the door.)
Old May 12, 2013 | 06:49 PM
TOM R's Avatar
cruise control, maybe headlight sprayers
Old May 12, 2013 | 07:28 PM
bcbp's Avatar
Abs and cruise control.
Old May 12, 2013 | 07:42 PM
SSL9000J's Avatar
I'm noticing a trend here...
Is the Disco cruise control really that crappy, or do most owners (like myself) just not care if it works or not?
Old May 12, 2013 | 07:48 PM
ihscouts's Avatar
My right foot.
Old May 12, 2013 | 08:07 PM
ihscouts's Avatar
The vacuum pump seizes with lack of usage (bad vacuum lines) and weather and is in a tight spot, hard to remove with it's vibration isolators. I got mine to work after direct 12V, sewing machine oil and stiff plastic vacuum lines. No problem in three years. Not the best design but a religious moment (witness a resurrection) once it works.
Old May 12, 2013 | 08:48 PM
CUpgt's Avatar
Cruise and ABS...I disabled the abs
Old May 12, 2013 | 09:10 PM
Sam95disco's Avatar
Crap, I forgot the abs and airbag lights are on. My moon roofs work, they just leak. They are sealed now.
