What spark plugs are best for a 98 Disco V8?
Old 12-29-2008, 07:37 PM
Default RE: What spark plugs are best for a 98 Disco V8?
Yes they are single ground.
Old 12-29-2008, 09:35 PM
VikingDiesel's Avatar
so OEM is single prong while people on here recommend the BOSCH 4 prong? Also, will the wires matter that much, can I still just go to NAPA or Advanced Auto and pick up some BOSCH or NGK wires?
Old 12-29-2008, 09:41 PM
Yes the wires matter that much, if you go cheap on anything go cheap on the plugs, NOT the wires.
I am on my third set of plug wires and I have only had my truck since April '07, I used Duralast wires, I will be buying Magnecors once I have the money.
I used Denso Iridium plugs and Duralast wires, the wires lasted a year, now I am on my second set of wires in 7 months, the plugs are still good, but the wires are junk.
They have been replaced under warrenty every time, but...it is a PIA to keep getting mis fires and taking the time to change out the wires every couple of months.
Old 12-29-2008, 09:52 PM
so NGK and BOSCH wires are junk? However, I should stick with the BOSCH 4 definitely b/c that's what the majority of people on here use and its the best?
Old 12-29-2008, 10:08 PM
Personally I do not think the +4's are all that great, but that is just my opinion.
The NGK and BOSCH wires will not hold up on a Rover.
Rovers eat plug wires for lunch, I do not know why, thats just the way it is.
Old 12-29-2008, 11:34 PM
so what wire and where can I buy them from a store that's NOT a stealership??
Old 12-29-2008, 11:54 PM
AK Rover's Avatar
http://www.lrrforums.com/store/index.php
Follow the link for both plugs and wires. Save yourself time and hassle and get the magnecor 8mm wires right away. You may be able to find them locally in a performance shop where you are but I doubt they will beat the price you'll find online.
I posted this on another thread but I'll say the same thing here since it applies. Talked to my mechanic today and he recommended staying away from the Bosch Platinum +4's. He said the engine was designed around a single ground plug and run just fine with them. His recommendation was either a single ground copper plug or the bosch double platinum. He doesn't think there is any advantage to the 4 grounds. I am going to try the +4's since I have already ordered them but thought I would throw in my 2 cents and what I was told.
Old 12-30-2008, 12:20 AM
llesra's Avatar
ORIGINAL: Spike555
How long have you been using those Kingsborne wires?
ive only had the kingsborne wires for a month but the combination of kingsborne 8mm wires and ngk platinum plugs with a larger than normal gap (0.45") work as well as the magnecor 8mm wires and bosch +2s i had in my old disco. ive heard a lot of good about kingsborne and wanted to try something different. it doesnt hurt that the wires were cheap.
kingsborne 8mm & ngk g-power
$40+$2.75(8)=$62
magnecor 8mm & bosch +2
$110+$4.50(8)=$146
Old 12-30-2008, 12:26 AM
ORIGINAL: llesra
ORIGINAL: Spike555
$40+$2.75(8)=$62
$110+$4.50(8)=$146
where are those kingsborne wires from? Auto part store, I want to hear anyone on here who bought wires from NAPA, AUTOZONE, ADVANCED AUTO... etc to see what they have to say about them?
Old 12-30-2008, 12:28 AM
llesra's Avatar
http://www.kingsbornewires.com/categ...?categoryId=38
Quick Reply: What spark plugs are best for a 98 Disco V8?
