Who can figure this out?
Old 11-23-2010 | 09:12 AM
okdiscoguy's Avatar
X2 with Cosmic. The dash gauge is the same sender as the computer. That said, I know the temp will fluctuate a lot without moving on the dash much.
  #22
Old 11-23-2010 | 12:32 PM
Dezert Rover's Avatar
I'll make a mental note of all this.... Just in case
  #23
Old 11-23-2010 | 01:31 PM
losinov's Avatar
So do the OBDII Scanners only work on 96+ models?
I have a 94 is there a scanner available that I could use for it?
  #24
Old 11-23-2010 | 05:26 PM
Cosmic88's Avatar
Your model year came with ( it should have anyway) a small display box which will tell you what fault codes your ECM is throwing. It is located under the passenger seat, on the outboard seat mount rails... behind the plastic facia piece that runs the length of the seat base.
This is OBD I (not compatible with II scanners) and can be read by TestBook and a few other diagnostic scanners. And yes, OBDII was employed by LR from '96 on.
  #25
Old 11-23-2010 | 06:28 PM
Originally Posted by Cosmic88
GOOD Puzzle Spike!
Thanks, just trying to get people thinking alittle and keep things interesting.
And since you were the closest your prize will be... you know when you pull apart a Oreo and the filling all sticks to one side?
Well you get the side with no filling.
  #26
Old 11-23-2010 | 06:29 PM
There are 2 different temp sending units.
One for the gauge and one for the ECU.
This one is for the gauge.
http://www.roversnorth.com/store/p-2...ge-40l-v8.aspx
This is the one that was bad.
http://www.roversnorth.com/store/p-3...olant-efi.aspx
  #27
Old 11-23-2010 | 06:43 PM
okdiscoguy's Avatar
I do not have the "one for the gauge" I have an alternator there...
  #28
Old 11-23-2010 | 06:57 PM
Cosmic88's Avatar
Is that 'cause I don't like the steel, spare disco wheels...?
After all that back and forth, I've been checking them out and I kinda like em a bit more now...AND I will conceed that they are a decent wheel. I mis-read a load rating on them. Thought they were rated at 750kg...wrong.
Now can I have the other half of the Oreo? Is it double stuff?
  #29
Old 11-23-2010 | 07:28 PM
Well, since you asked nice...
  #30
Old 11-24-2010 | 04:35 PM
tweakrover's Avatar
interesting, i did not know about 2 sensors i may look into changing that to see if i can fix my funky idle while hot.
Quick Reply: Who can figure this out?
