Why would they do this?
Old Jan 20, 2021 | 06:29 PM
SafariDiscoNoob's Avatar
Question Why would they do this?
I am a new 95 D1 owner, not new to owning old cars, and just like old cars there are certain things that are customary in doing, small mods here and there. Now there are couple of these strange things on the car that I don't understand as to why they could have been done, if someone could chime in I would really appreciate it.
1. AC compressor is disconnected from within the engine bay, see pic attached. Is this a common thing? I mean if AC compressor is not working then its not working, why go through the hassle to do this?
2. Has SRS and ABS lights, read that there is some sort of a ecu under the drivers seat, when I checked the black cable with the yellow strip is there however there is no ecu or anything of that nature. Is the intention behind this to not have the air bags deploy?
-Found lots of snail shells near manifold, which is interesting, never had I seen this.
-What's the consensus on safety of these spring spacers
1. AC compressor wire cut.. Is there a specific reason for this?
2. Under the drivers seat.. Is this for a SRS computer or something of that nature?
Shells under manifold. lol
Terrafirma Spring Spacers
95 D1
Old Jan 20, 2021 | 06:37 PM
Best4x4's Avatar
95 OBD1 Diagnostic box with red LCD read out is under the passenger seat. OEM CD Changer is under the drivers seat if equipped. Spacers are fine, and the AC Compressor thing = clueless as you can simply unplug it lol. Here is a pic of my 95 D1
Old Jan 20, 2021 | 10:07 PM
Talking
Ok thank you. Im going to try to connect the compressor, fingers crossed nothing blows up.
Old Jan 20, 2021 | 11:25 PM
Icannap1's Avatar
Snail shells = rodent has been hanging out and having a meal. Check your wiring sometimes they will dine on your wiring harness.
Old Jan 21, 2021 | 12:04 AM
How does that happen?
Old Jan 21, 2021 | 08:09 AM
leecatd8209's Avatar
Rodents need to chew constantly the keep their teeth down. Wiring insulation (and sometimes the wires, too) seems to be a favorite chew toy for rodents of all types. Back home it was often porcupines in particular for whatever reason.
Old Jan 21, 2021 | 06:38 PM
WaltNYC's Avatar
Wild guess.... the A/C made the truck overheat.
Old Jan 21, 2021 | 08:18 PM
Best4x4's Avatar
Probably due to both Efan's being INOP.
Old Jan 22, 2021 | 08:08 AM
WaltNYC's Avatar
Yep. Typical failure point. I'd also have the radiator serviced (re-cored if needed) and t-stat replaced with a Stant 45858
Amazon Amazon
The cooling system on these trucks get old and without that system operating well, they overheat, warp heads, and blow head gaskets.
(translation: Efan = two electric fans that kick on whenever A/C is running and/or coolant temp rises to 212 deg. They are located behind the front grill in front of the radiator.)
Old Feb 13, 2021 | 05:04 PM
That's what I initialy thought.. But could just not use it..
Has the efans, seem aftermarket, wired to a separate relay and to temp sensor.
[QUOTE=WaltNYC;758535]Yep. Typical failure point. I'd also have the radiator serviced (re-cored if needed) and t-stat replaced with a Stant 45858
Amazon Amazon
Thank you for the link, Radiator was replaced in May 2020, will get that thermostat just in case, because radiator was replaced at Midas... according to carfax.
