Window ECU Issues!?
Hey everyone, does anyone happen to have the circuit diagram for the window ECU? I have all of the other diagrams but the ECU is not letting power through itself properly so none of my windows work. Once I have the diagram my dad (who is an electrical engineer) can basically test and rebuild the board so they will work. Cant seem to find it anywhere even with many hours searching online, not in the RAVE, not in the electrical manual, nothing...
might be the easiest way to get things working
https://www.ebay.com/itm/OEM-Land-Di...kAAOSwSxVcWiUe
or use it to troubleshoot yours, and you'd have a spare for next time.
I took my ecu out followed the aluminum lines on the underside and soldered wire between the the 2 points where it burned the aluminum,then i put permatex on it.this was 5 years ago and windows are still working just fine.land rover made the mistake of sending these out to a company that used very cheap solder and it turned out to be to brittle.if you find loose points in the solder and you just re-solder these points all will be good again.
To help everyone out that seems to be reading this, I ended up ordering an ECU from ebay and it fixed every window except one. I pulled it apart and noticed a lack of grease on the assembly so greased every window unit and now they all work perfect. For some reason though the passenger window moves much slower than the driver, but still works for now so not worried about it!
